BOX HELP! Please and thank you (2) SA12s
JCarlosss
Needing some help with designing a box for 2 Sundown SA12s. Going into a '14 Charger so I'm a bit limited on space. Anyways what I have to work with is L18max,W32 max, H 15. Want to hit lows but not only lows. A well balanced one is ideal. I would greatly appreciate it if anyone would be willing to help me out. TIA
The amount of power you're applying to them will be helpful as well. And you don't really have enough space for 12's. It's 4.4ft^3 gross volume. Add subs, bracing, and a port (assuming you want ported) and you'll be cutting that space in half.
2 minutes ago, reedal said:
You don't have the space for them to have the airspace they need
I could make the box length longer.
the dimensions listed are for it to sit in the back. I had them in a pro box let me see what the dimensions were for that maybe I can add more space
no one else will tell you this but those sa-12's will like 2.5 cuft more than they will 2.0cuft. even if you overpower them, tune to about 32-33hz. so i dont think you have the room unless you want to choke them.
edit: 2.5 per sub
  • Who's Online   0 Members, 0 Anonymous, 6409 Guests (See full list)
