ground straps/bond straps
Yes, You'll just end up doing a big 4 instead of a big 3.
You run one from the engine to the battery, engine to the chassis, and chassis to the battery, and as i always like to say, you can never have enough grounds cause if grounds are broken, they can do some very funky things with newer cars.
One thing you always need to check is the strap between the starter and battery cause that can be a big headache if you ever forget that, leaving you stranded thinking your starter went out.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I forgot to mention that I have the big 4 in 2/0 wire. What I'm trying to figure out is if its important for the grounding/bonding straps that come from factory to be on the car. My car from factory suppose to have a radio suppression package (53M) which consist of the following bonding grounds:
Hood to body (LH/RH)
Engine to dash panel
Engine to frame
Tail pipe to frame (LH/RH)
Decklid to body (LH/RH)
Body to Frame rear (LH/RH)
My car is missing a few of these factory bonding straps.
Most everyone leaves them in place and just adds on, electrons will take the path of least resistance, and you can never have enough grounds on a car, especially modern cars with all the computers they have.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Engine to frame
replace whats missing.
https://www.youtube.com/channel/UCWd1ShRnPbDG9ppgJKpumdA <---- show some love to my channel
Alpine MRH-F255 (old school), sub channel not used
Skar audio VX35-ST tweets in front  (invest in them they are worth it)
kicker zr120- nice underrated amp
Powerbass s1204 subwoofer in a 1.75 custom slot ported enclosure tuned to 30hz
Front doors Prv 6mb200s 8ohm
Alpine type-e 5.25 in dash took a shave and a hair cut.....- not in use
Rear doors alpine 6.5's model/series unknown but they are loud as hell
Factory alt
3.5 farad cap, does the job for now.
Deck is a pioneer mixtrax 700bt model
And my baby my Pioneer EQ-6500 i got for 10.00
Back-up amps- Ma Audio 598i, kicker zr120, my highly under rated JBL LC-A502 1xx watt amp...
On the side- Quantum tweets not yet installed
  • Who's Online   0 Members, 0 Anonymous, 4582 Guests (See full list)
