06RTCharger Posted February 28, 2017 Report Posted February 28, 2017 Is it ok or normal to use one rca into a sub amp? My HU gives out a Left and right output for subs. I will be using one 2channel amp (bridged) per sub, two sub amps and two subwoofers. So for running the rca, would it be ok to run "left sub output" to one amp and "right sub output" to the other amp? Thats just one plug in each amp. Or am i supposed to use Ysplitters?
ShadeTreeMechanic Posted February 28, 2017 Report Posted February 28, 2017 I would use a "Y" splitter. I had a sub amp on only 1 RCA one time and it had a turn off thump. I got a "Y" splitter and the thump went away. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
06RTCharger Posted February 28, 2017 Author Report Posted February 28, 2017 Ok thanks, that kinna answers my other question i posted about preventing turn-on thuds.
