I know less now
BBQracer
So, I built this box thinking I knew what I was doing.......
I didn't, I was going to port it but after screwing up my calculations I was told I would need a mile long port.
I guess I'll be sealing the box now. So to simplify the effort I'm going to ask people who know WTH they are doing.  Below are the specs.  Do I just seal it up as is or should I reduce the box size?  The current box is as big as it's going to get.  It was built to fit under the rear seats in my Ridgeline.
Speakers VFL-8D
look at using NVX DA7501 for my amp
Drawing1 Model (1).tif
Your image for the box dimensions isn't showing up for me, so I can't give you any specific recommendations.  However, sealed boxes are really hard to screw up and will work with a wide range of box sizes.  Unless your box is WAY oversized you are probably fine.  If you tell me what the internal volume is I'll be able to give you a better answer.
Builds:
OP where did you get the mile long port claim. that's false, there's a ported box for two of those subs posted a few pages back that you may want to examine, the 0.85 cf per driver on rated power would be ok for sealed but those subs will lack low end significantly on sealed, I would recommend rebuilding your box properly using a ported design.
I know this doesn't necessarily answer your question but I ported my subs on .75 cubic feet per sub (after factoring their displacement) so you're not very far off with the space. Hopefully someone else can help you discover more about the port you require with that design. I don't think it's going to be a mile long port though.
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
  • Who's Online   1 Member, 0 Anonymous, 1661 Guests (See full list)
