I am new in this I bought the DD-1+ And the CC1 because I like my music sound great but the overlap adjustment is bad because I do not understand what is that I got 8 ( 8inch) speaker (beyma) each one can handle 250 rms I got a ds18 3500 full range for this and rockford 300x2 for 4 tweeter (beyma) but the overlap drive me crazy how much overlap I can do ?
On ‎1‎/‎2‎/‎2017 at 3:47 AM, audiofanaticz said:
The overlap on the dd-1+ is done differently than the DD-1.
With the DD-1 you are limited to the few tracks for each 40hz and 1khz on the disc that was -5, -10, and -15db (iirc).
The DD-1+ there is just 1 tone for 40hz and 1khz.
With the overlap you turn the knob to the desired overlap. So if you wanted -5db like how you set with a dd-1 you would turn the dial until you see +5db, then your gain is set with an equivalent to the -5db track from the dd-1.
However with the dd-1+ you are not limited to those 3 tracks and can set it to anywhere in between which you cant do with the dd-1 unless you make your own tracks.
Plus with the dd-1+ you can tune a customers amp and right it down the overlap and voltage on your copy of the receipt. Then if they ever come in with any blown woofers you can verify with your dd-1+ if they messed with the amp settings at all and jacked the gain up, blew the woofer than they lowered it back down to claim they didnt touch anything. Kind of nice, but not something beneficial to everyone.
On ‎1‎/‎2‎/‎2017 at 6:32 AM, audiofanaticz said:
Here we go again..................................
I said EXACTLY what the gain overlap is.
I also said you are not adding +db to it, it is actually -, but when you turn the knob to add overlap you are being showed what you are adding as +, but it is actually -.
The + simply implies that you are adding overlap to your setting.
So if you set your amp for +10 db of overlap, it would be the same as using the -10db track on the dd-1. I just said this...
You use overlap because music is often not recorded at 0db (unless your playing test tones). A lot of the edited music bassheads listen to is -5db, so you would use the -5db track on a dd-1 OR add +5db of overlap on the dd-1+ (they are the same setting. So you are matching your overlap to the music, otherwise if you play it at 0db it is quieter than intended.
On ‎1‎/‎2‎/‎2017 at 0:38 PM, meade916 said:
here is a good read from the David Navone website (by Richard Clark):
Proper adjustment of an audio system begins with the initial selection of components. Component interface should be considered in regard to signal level, input/output impedance, and wiring and connector types. Failure to consider that some components are just not well suited for use with certain other components can doom a system to poor performance. And just for the record — don’t assume that just because you have decided to go the “everything from one manufacturer” route that you will be spared. If we can assume that attention has been given to these issues we are faced with the basic requirements for level setting.
The real heart of the issue is that every component has a noise floor below which it cannot pass a clean signal. Every component also has a maximum level above which it cannot pass a signal without severe distortion. In operation, it is critical to make sure the signal stays as high above the noise floor as possible without exceeding the maximum undistorted level. This is important no matter what the brand, price, or design the equipment may be. It should be acknowledged that an experienced technician can probably do a quick “tune it by
ear” and get most systems pretty close to optimum, but it is just as true that to achieve 100% of a system’s dynamic performance, the use of test signals and at least basic test equipment is needed.
Optimal Level Setting
As we mentioned before, a system that is not set up properly will have excessive noise or distortion or more likely both. With many systems costing thousands of dollars it is really silly to consider that level matching is not worth at least a few dollars and a little time. If you have a thousand dollars invested in your system and you improve it only 5% with a little tweaking, that’s a value of at least fifty dollars the way I see it. The fact is that in most cases the overall dynamic range of a system can be increased several dB with precision tweaking over what even the best “ears” can do. If you want to consider value, a mere 3dB is like doubling the value of your system.
So how do we go about this important final system tweak? First off forget all those statements such as “set it at 3/4” or “turn such and such to here.” Such comments are the babblings of techno-idiots and should be ignored by anyone serious about quality audio. No doubt you have heard such poor advice, as well as the other extreme, where the process is described in detail that would rival brain surgery. Really it’s not as complicated as its importance would suggest. All we really want to do is insure that when a signal starts out at the beginning of a system that it passes through the entire system as high as each component will allow without adding distortion. When a system is adjusted for absolute best S/N and lowest distortion, all the components will reach overload at the same time.
Begin With a AHB Signal
There are really only a couple things that are needed to do a professional job of level setting in an audio system. A good stable low distortion signal is the first thing required. I suggest you use a frequency of somewhere in the 500 Hz to 1 KHz range. A suitable signal would be what we call recorded at “all high bits” (AHB). This means that the signal outputs the highest voltage that would ever be encountered from an undistorted music source. There are numerous test CDs that contain suitable signals or you can burn your own from one of the numerous web sites that contain test signals.
Using An Oscilloscope
Once we have the signal we need a way to monitor it as it is passed through each stage of the system. There are several ways that work well and I will cover three of them. Naturally the best ways cost the most but either will work with patience. The best way to monitor any electrical signal is to use an oscilloscope. While this may sound rather exotic it really isn’t. Considering that today a scope can be bought for as little as 100-200 dollars (even less on eBay),
it is a good investment for anyone who is serious about a future in audio. Personally I would place its importance right up there with a drill or a DVM.
Once this simple procedure is finished, it is time to adjust the power amp gains. If we lived in a perfect world our systems would always have more power than we could ever use. Unfortunately it’s rarely that way. If we set our gains “textbook perfect,” the musical signal would never be able to produce a clipped signal. That is the good news. The bad news is that since the crest factor (peak to average power factor) of music is relatively high, the average power of most music signals is over ten to one or about ten dB. What this means is that in a perfectly gain matched system; the highest average power we can ever use from our power amps is about one tenth! This means that with a 1000 Watt power amp, the most long term average UNDISTORTED power we can listen to music is about 100 Watts or even less!
Gain Overlap
Fortunately short term music peaks don’t last very long and we can cheat just a little and get away with it with little or no audible downsides. The fix for this is what is known as “gain overlap.” Gain overlap is an intentional mismatch in the final gain adjustment done right at the power amp. This procedure allows for short term music peaks to be clipped and at the same time allowing the average level of signal to be increased. The net result is a large, noticeable increase in how loud the system will play.
Much testing of skilled listeners has shown that the added distortion of a 10 dB gain overlap is extremely difficult to hear. It just so happens that the real bonus of a 10 dB gain overlap is that the system will play at a level that is perceived by listeners to be fully twice as loud. Of course you can choose the amount of overlap you care to incorporate, but less overlap reduces the usable loudness, and more overlap leads to distortion audible.
Several years ago at Autosound 2000 labs we actually produced Test CD#104 “Level Setting.” This disc demonstrates the actual audible effects that result from different degrees of gain overlap. The test disc also demonstrates the differences in loudness that result with each choice of overlap. Those that are new to this concept or are uncertain on just how they want to adjust their respective system might want to audition this disc. Gain settings from 0 to as high as 20 dB of overlap are demonstrated with varying steps in between.
(Note: The Autosound 2000 Test Disc CD#104 “Level Setting” is available from Automedia / Car Sound And Performance for only $15.00 at www.carsound.com)
The gain overlap is achieved by doing the very last amp gain adjustment with a test signal that is reduced in level by the amount that you want to have the gain overlapped. As such, a 10 dB overlap would be done by adjusting the amp gains with a test signal that was 10 dB less than the “O” bit signal that is used for the rest of the system components. In addition to demonstrations of the effect the actual signals necessary to make the needed adjustments are included on the CD#104.
Summation:
When it comes right down to it, there is little that one can do or spend on a system that can rival the sonic improvement that comes with proper gain adjustment of the system as a whole. A system adjusted for perfect gain matching is like chain that has equal strength in every link. In such a chain every link will fail at the same instant. A properly adjusted system with gain overlap at the amplifier is like a carefully engineered electrical system that offers maximum performance but has a fusible link.
More here:
http://davidnavone.com/level-setting/
https://www.stevemeadedesigns.com/board/topic/207759-what-is-gain-overlap/?page=2
