sp4 getting stinky
Got an sp4v2 15 on a skar 3500 at half ohm,. gets stinky after about 30 seconds.  Box is 3 cube tuned at 40.  Just a temp box.  Swapped it out for my skar zvx 15 and i can play that thing all day long.  I know FI uses a shit ton of glue, but it is kind of concerning.  Anyone had this problem with fi subs before?  gain set with dd1
2004 Jeep Liberty Limited
2 13w7s
skar 3500
cnf mids (soon)
xs batteries
What track did you use?  You may still be clipping depending on music you are playing and what track you used.  My hunch is that's the case here.
If the sub is new it WILL smell for a while...
Based off ratings you are in theory overpowering the sub BEFORE impedance rise...  plus you lose cone control running amp at 0.5  (dampening factor) Although I would think none of this actually applies to your set up....IMO
should be able to do just what you're doing.  SP4v2 rating goes to 3500 watts RMS from 3000 on v1 correct?
What is voltage doing?  You can tell you're clipping if it's dropping a shit ton with the SP4 in and you really know your set up and what voltage normally is
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
It shouldn't get stinky after 30 seconds though (unless new)
Do you have any way to watch temps on VC or dustcap?
Tuned in to see where this goes, other suggestions, end result when you figure it out etc.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
set with negative 5 db track.  drop to 12.5 lowest.  im just baffled why the zvx hasnt exploded and the fi is not happy. sub is a month old its sitting in my room next to the other one i have, pickig up an ampere 7500 this weekend for the final build.  ive clamped 3200 wattts on it==]
2 13w7s
skar 3500
cnf mids (soon)
xs batteries
aight thanks man.  I know those subs are beast and i've scoped a few songs.  i'm clean on burps and a slight slight clip on some tracks.  Like i said, no issues with the zvx, i just didnt wanna blow a 500 dollar sub so i took it out.  I'm sellin the zvx and that 40hz fart tube and puttin in a lvl 4 18 this weekend.  Should have both sp4s in and the ampere hopefully end of april.  Lemme know if u have any other advice on the sp4s
2 13w7s
skar 3500
cnf mids (soon)
xs batteries
  • Who's Online   0 Members, 0 Anonymous, 6960 Guests (See full list)
