What kind of enclosure should I buy?
3 minutes ago, bmwking said:
it really was ideal in terms of placement, output, and room taken up.  we already had a coffee table, so it was merely replaced.  with one that shakes the windows.  if it's an option, it's one worth thinking about
was it a dayton 15" subwoofer?
7 minutes ago, THE BASS LOVER said:
So how loud is the single 15" vs my current klipsch sw-112? it is 116db @30hz and 106db @40hz but i'm not sure if this is rms or peak db for the klipsch? but would that single 15" dayton out preform the klipsch this is my main reason for upgrading?
The Dayton RSS390HO-4 in a 4 cu ft enclosure ported to 28 Hz on 800 watts RMS (what its rated for), should put out about 133 db at 30 Hz and 132 at 40 Hz.  These numbers are estimations based on simulation software, real world results may vary, but you can rest assured it would stomp all over your Klipsch.
Builds:
Ok sounds about the right deal i'm really thinking about getting this 15" Dayton subwoofer is there a different site that may sell that same sub enclosure from what you have provided above?
Not that I know of.
Builds:
no, 4 infinity 8s actually.  but there's no reason you couldnt do a very similar setup with a single 15 im sure
8 hours ago, Triticum Agricolam said:
Not that I know of.
When I get this subwoofer will I be able to hook it up to my amplifier in bridged mode but what I have always done with subwoofers was to invert them from normal 0 degrees to 180 degrees just by reversing the polarity of the wires how would I do this with a bridged amplifier?
Just switch the wires at the sub instead of the amp. Same deal.
