oldsoundguy Posted April 9, 2017 Report Share Posted April 9, 2017 I have been playing with the torres box build for this box and it seems ok but I wanted your advise. DC recommends 1.25 net and not bigger than 1.50 I will be running it off 1200w The box should not be more than 23 long 14.5 deep height can be what it needs to be. Thank you 9.5" Mounting Hole Diameter 11" Outside Driver Diameter 12.5" Motor Width 7" Weight 20.5lbs VC Diameter 3" Displacement .16³ ft Magnet Weight 18lbs Power Handling RMS/Peak 900 / 1800 Impedance (Ohm) D1/D2/D4 Sd 481cm² Vas 28.99 liters Cms 0.09 mm/N Mms 225 g Fs 35.4 BL 17.2 N/A Re 3.6 Ohm Le 3.5 mH Qms 8.33 Qes 0.617 Qts 0.574 Xmax 23 mm Ref SPL @ 1 watt 85 dB ([email protected]) Suggested Sealed 1³ ft Suggested Ported 1.25³ ft 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
Joe X Posted April 10, 2017 Report Share Posted April 10, 2017 If you don't want to be peaky the 1.25-1.5 net range is fine, raw port area of 25 square inches should be enough in that box size range and 1200W of power with a mid 30s tuning. Anyways, if you want a little more box efficiency and get slightly peaky 1.75 net would work well. Any issues with a current box you are looking to replace? Link to comment Share on other sites More sharing options...
oldsoundguy Posted April 10, 2017 Author Report Share Posted April 10, 2017 Not replacing a box I am going from a M3-8 to the level 3 12. Any chance you could do a design? Thank you Joe I would like to stay in the 1.25-1.50 range. Again the depth of the box is 14.5 the length is 22 and height can be what it needs to be. Thanks Torres is giving me trouble. Hard to get everything to line up. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
Joe X Posted April 10, 2017 Report Share Posted April 10, 2017 Ok if you just want me to lay out something 1.5 net for that sub then there it is below, it's made with the same aimings as the box in your profile, figure is just an assembly guide: Link to comment Share on other sites More sharing options...
oldsoundguy Posted April 10, 2017 Author Report Share Posted April 10, 2017 Thank you Joe. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
oldsoundguy Posted May 6, 2017 Author Report Share Posted May 6, 2017 Just an update, I built the box that Joe designed for me and it sounds real good. Here are some pics of the build. Thanks again Joe 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted May 7, 2017 Report Share Posted May 7, 2017 That looks really nice! Good job. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Joe X Posted May 7, 2017 Report Share Posted May 7, 2017 Thanks for the pics oldsoundguy, that's great build quality! Glad it went well for you. Link to comment Share on other sites More sharing options...
