Welcome to SMD. I would do the big 3 and run 1/0 wire fused at the battery. That amp does about 2k at one ohm and is power hungry. I would expect it to want about 2౦0 amps. Get a volt meter and keep an eye on your voltage. A high output alternator would be good too.
Pioneer 80PRS
There are not many great amps at 10 cents a watt. I ran an m4 for over a year at .5 ohms and while it did live it wasn't the cleanest amp I ever had. Most people on a budget buy used equipment. Brands to look at are DC, audio leigon, soundqubed, skar, to name a few. I'm sure people will chime in with more to look at. I bought an FSD 5k used from a member here and I love it.
Pioneer 80PRS
You would have to get an amp that could do .5 and that m5 might. It might not. I put my m4 at .5 because I wanted more power and was willing to buy a new amp to get what I wanted. I didn't care if it fried and got lucky. The amps that people run at .5 are not rated at .5 so the warranty is void. Running at .5 also requires more power to run because the effeciency is lower. You should save up some more money.
Pioneer 80PRS
