Ratski Posted May 6, 2017 Report Posted May 6, 2017 so im on the fence about one of my subs. i get a lot of cone noise out of the right rear sub(i think) so i was thinking well maybe my box is coming apart. i gave it the once over and everything lookes fine to the naked eye. seems solid. so im thinking i have blown the sub. i have two fi audio 10" ssd-d1 running on a sq-3500. only thing i have changed is i re-did some grounds from my battery bank to the frame, so i dont think its anything from that. im just not sure because i all the other subs i have blown crackle at all volumes or have melted down, this one not so much
DTS909 Posted May 6, 2017 Report Posted May 6, 2017 I have 2 fi q's i got new and had coil rub on both subs. Took 1 of the subs I thought was bad to fi and they reconed it. When I got it back and played it with the other one I had the same thing as the first one I took in. Took the older one to fi and could not duplicate the rub. Said screw it and have been running the snot of them. I put some weather stripping between the gasket and surround to try and align the coil. Helps a little bit. Going to recone them to d2 after I switch them out and get my smd mini's running! VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Kyblack76 Posted May 6, 2017 Report Posted May 6, 2017 Pull it and free air it. Meter it. It's not rocket science. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Ratski Posted May 6, 2017 Author Report Posted May 6, 2017 4 hours ago, boomintahoe said: Play inspector. Know how to do that? no i do not know how to do that.
Ratski Posted May 6, 2017 Author Report Posted May 6, 2017 11 hours ago, DTS909 said: I have 2 fi q's i got new and had coil rub on both subs. Took 1 of the subs I thought was bad to fi and they reconed it. When I got it back and played it with the other one I had the same thing as the first one I took in. Took the older one to fi and could not duplicate the rub. Said screw it and have been running the snot of them. I put some weather stripping between the gasket and surround to try and align the coil. Helps a little bit. Going to recone them to d2 after I switch them out and get my smd mini's running! i think i will pull the one i think is making the noise. its a common chamber sealed box. give it the ole once over. i was only concerned because it started making the noise out of nowhere.
boomintahoe Posted May 9, 2017 Report Posted May 9, 2017 On 5/6/2017 at 10:15 AM, Ratski said: no i do not know how to do that. Then remove thyself from car audio at once.
