Different voltages on same power and ground
My battery under the hood charges about 14.4 and the battery in the back sits at 12. The Boston amp reads 14.2 and the SQ reads 12. What would cause this?
2017 Honda Accord Touring
Build coming soon
Sounds like you have a bad connection.
Pioneer 80PRS
For sure my power wires are solid but maybe I'll try to move my ground. It's been in the same place for over a year though and there is no rust, corrosion etc.
Build coming soon
I assume that the Boston at 14 is not hooked to the battery that is 12?
Pioneer 80PRS
I have 2 runs that come from up front. One goes directly to that battery, the other goes to a t distribution block  (battery and Boston amp). So yes but indirectly.
Also today on another test at startup:
Boston amp:14.6
SQ:13.9
Kinetik battery:13.9
I haven't checked at full tilt due to not having an open space to do so and don't want to piss off/advertise to the neighborhood.
Build coming soon
Sounds like a bad connection between the T distribution and the battery.
Pioneer 80PRS
All connections and fuses are good. Anything else to look for?
Build coming soon
Take your connections apart and look at them.
Pioneer 80PRS
The only way a wire could have a different voltage from one end to the other is if there is a voltage drop across it or one of the connections. The only way to have voltage drop across the wire is if it is conducting current. That is a very big voltage drop at no load so it has to be a connection going to the terminal that is reading the low voltage. Either positive or negative. You will have to dig into the problem to find the cause.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 4069 Guests (See full list)
