Different voltages on same power and ground
Sounds like you have a bad connection.
Pioneer 80PRS
I assume that the Boston at 14 is not hooked to the battery that is 12?
Pioneer 80PRS
I have 2 runs that come from up front. One goes directly to that battery, the other goes to a t distribution block  (battery and Boston amp). So yes but indirectly.
Also today on another test at startup:
Boston amp:14.6
SQ:13.9
Kinetik battery:13.9
I haven't checked at full tilt due to not having an open space to do so and don't want to piss off/advertise to the neighborhood.
2017 Honda Accord Touring
Build coming soon
Sounds like a bad connection between the T distribution and the battery.
Pioneer 80PRS
Take your connections apart and look at them.
Pioneer 80PRS
The only way a wire could have a different voltage from one end to the other is if there is a voltage drop across it or one of the connections. The only way to have voltage drop across the wire is if it is conducting current. That is a very big voltage drop at no load so it has to be a connection going to the terminal that is reading the low voltage. Either positive or negative. You will have to dig into the problem to find the cause.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1714 Guests (See full list)
