Dont know much about them, but if there not pulling atleast 40 amps of current to blow that fuse then theres something wrong with the fuse block or that amp.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
This all resembles to meglo test he just did about under powering.
You CAN NOT blow a sub from less power. The sub blows from clipping from the amp or the hu.
Get a bigger amp and milk the gains a lil and your fine.
I never said anything about blowing a sub from underpowering.
You blow it from clipping.
I intend to upgrade electrical first and see how it does from there.
I do plan on getting a Sundown 1500 though. :wub:
thats wut i was askin this for. something cannot be right if i havent blown that fuse yet
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Here ya go.
1000 watts/14 volts is 71.4 (ish)
71 amps of current multiplied by 14 volts is 999.6
under perfect condtions you should be getting 999 watts of power from that amplifier.
What this amounts too is that amp is not pulling more then 40 amps of current and is well below its ratings of 1000 watts if it is rated at that. Or rather that the fuse is just letting that voltage by for some odd reason my guess is the amp is crap.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
also the manual says it uses 160 amps max at 1 ohm which comes out to 2240 watts
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Now if you want to go the restance route we can get really in depth what restance are you running that amp at.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
4 ohms right now
ok. now at 4 ohms that amp will see 4 full blocks of restance so the current draw will reside in a defect.
The formula for that is I=V/R
I being your current draw.
14v/4 is 3.5 amps of current draw is what sub see's
Amp- Us-Amps M2D2
Have you had enough
I will be the one
The restance is not going to effect the current draw of the fuse up front, thats just what the sub sees. Refer to the first post for your fuse problem.
I should have my own section for this brain bender.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
Your fuse isn't going to instantly blow from being under rated. You can exceed its limits by a fair bit for short bursts and not having it blow. Also, keep in mine the consumption rating of your amplifiers is at FULL power, music is fluctuating and varying and for the most part, not constant. Load the amp down and play test tones and you'll most likely melt the fuse.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
