ok. now at 4 ohms that amp will see 4 full blocks of restance so the current draw will reside in a defect.
The formula for that is I=V/R
I being your current draw.
14v/4 is 3.5 amps of current draw is what sub see's
this is very confusing
in order to attain my rms voltage i found i need 63.25 volts according to this http://www.stevemeadedesigns.com/board/ind...showtopic=14543
which is about 15 amps going to the subs @ 4 ohms
so i need 71.4 amps coming in and 15 amps goin out correct?
but if im only gettin bout 30 amps comin in then that means i have about 6 amps goin out (i used a ratio, its prolly wrong)
i lost wut i was trying to figure here nm
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Your fuse isn't going to instantly blow from being under rated. You can exceed its limits by a fair bit for short bursts and not having it blow. Also, keep in mine the consumption rating of your amplifiers is at FULL power, music is fluctuating and varying and for the most part, not constant. Load the amp down and play test tones and you'll most likely melt the fuse.
No thats wrong. As soon as the fuse sees more then what amperage its rated at it will blow. Thats what its made to do.
So your saying you can put a 150 amp up there on 4 gauge wire and pull 200 amps and fry the wire?
The fuse is to protect the wire that whole statement is wrong.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
Honestly i wouldnt go by that chart for anything. The new hybrid amps are blowing all laws that thing is geared on.
But for your amp yes that is right.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
I calculated just over 400w out of the amp. Maybe less with voltage drop.
40 x 13 x .8 = 416
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
For a short period of time, you can. I'm talking less than 1 second.
PS: How long is the piece of 4awg wire? :P
My Youtube Videos
40 x 13 x .8 = 416
Why are you using .8?
Amp- Us-Amps M2D2
Have you had enough
I will be the one
Theres no way its gonna pull more for just less then 1 seconds.
And in the end thats still wrong.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
im guessing 80% efficiency rating
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Current (Limited by your fuse) x Voltage (13v is probably a little too generous, expect low 12s on actual voltage drop) = W x 80% (Typical efficiency, could be more, could be less)
My Youtube Videos
Makes sense, i never do it but makes sense if you want too.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
