If you don't, your results are near meaningless because they could be exaggerated by 20% or even more. What I'd do for an actual 20% increase in power!!
Also the calculations based on 14v a likely wrong also, check your amp's terminals with a good multimeter at full tilt and see what you really get.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
You will never get the exact wattage out of that anyway so why try so hard too?
A rough estimate is good enough.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
guess its time to run it at 1 ohm
at least then itll be close
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Aslong as your amp like 1 ohm and wont fry.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
Really?
Imagine if everything was made with 20% tolerances..
Also, 20% is a fair amount of power, 200w on 1000w and as you increase the power it gets more and more. I'd want to be as accurate as I can be with my system.
My Youtube Videos
Really?
If you really wanna be a smartass with me then here ya go.
How would you know the exact efficency of that amp anyway?
A normal class d amp is around 93% efficent as a average.
How can you multiply that by .8 and be dead on?
That amp could push out 75% efficent or 90% and your readings are all off.
Once again a rough estimate.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
I wasn't being a smartass but in answer to your questions.
Unfortunately I've never messed with one before (I don't even think we have them over here) But I can use typical class D design and atleast give a prediction. You could always contact the manufacturer or check your manuals.
I've never seen that before. I sure as hell know my Class Ds aren't 90% efficiency.
As I said, it's a prediction. It's better than multplying by 100% and being further out. Never said it was dead on.
This being said, I'm not here to convince anybody just to put some word out there.
My Youtube Videos
stop fighting u 2 im glad ur both helping me
both equations are rough estimates technically. either way the amp is way off the power i need
so ima run it at 1 ohm (and it is stable at 1 ohm deafdreamz) supposed to be 2300 but its more like 1600
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Dont matter aslong as you get your 1000watts bro.
The only reason i got pissy is because he thought his math was dead on and nobodys will be. If you dont have 90% class d amps down there then i would order some from here.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
I buy the best we can get locally. I've got my Digital Designs Z series amps on the way and T40001 Rockford sitting on my floor for a rainy day, they're a lovely amp!
On topic though, loading down to 1ohm will certainly prove whether or not your fuse is up to the task. :)
My Youtube Videos
