I buy the best we can get locally. I've got my Digital Designs Z series amps on the way and T40001 Rockford sitting on my floor for a rainy day, they're a lovely amp!
On topic though, loading down to 1ohm will certainly prove whether or not your fuse is up to the task. :)
ill prolly refuse it when i change it to one ohm
the amp can take 160 amps so wut should i fuse it at?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
what gauge wire?
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
Ouch bud, i wouldnt run 1000 watts with 4 gauge wire but thats just me. Id go with a 100amp fuse.
Amp- Us-Amps M2D2
Have you had enough
I will be the one
i am planning on upgrading it cause this is a kit i got from wally world
im goin wit 2 runs of 0 gauge. why 2? why not
money is the reason i dont have it now
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
stop fighting u 2 im glad ur both helping me
both equations are rough estimates technically. either way the amp is way off the power i need
so ima run it at 1 ohm (and it is stable at 1 ohm deafdreamz) supposed to be 2300 but its more like 1600
1600??
i thought that this amp put out at least 2000 rms at 1 ohm
1999 Eclipse N/T
12'' Fi BTL
Gp3000d
PM D3100
1600??
i read it was 1600 somewhere on here
im not sure if it was benched or if it was just an estimate
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
1 guy tested an A3000 on term pro or something and said it was only putting out 1300 watts, but I have seen numerous bench tests saying 1900 and up...I guess it all depends on the one you get. Maine were drawing a ton of power. I have an Iraggi 280 amp alt. a red top and 2 HC800's and I would still get voltage drop to the low 13's.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Wow I'm seeing a lot of uneducated posts in here. Somebody needs to by a clamp meter and learn to do some real math. I've clamped my Sundowns and seen 320a of current draw without blowing the 160amps worth of fuses. Fuses can take bursts for more than their rating without blowing. Anytime you calculate an amps actual output using its input #s you must calculate efficiency. You find out efficiency by clamping the amplifier, getting the real input and output #s, and then doing the math. Average efficiency for class d amplifiers @ 1ohm is around 70%. I know this because I've actually tested different amplifiers and calculated the results. All the guessing in here is a waste.
can u come down and test my amp?
i was told its a good amp and i wanna get my power out of it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
