1 minute ago, strangeduck said:
i dont know a lot about why the spider fails or what happens when it does. i was assuming it clogged up so no fuel would be gettin to the cylinder
The diaphragm on the regulator goes bad and dumps fuel in the intake, the spider goes bad in one of two ways, either the poppet valve that sprays the fuel into the cylinder melts and gets clogged up or the lines leading too them inside the intake become brittle and crack and dump fuel inside the intake.
Yep, they sure are.
If you end up doing it get the upgraded one that has actual injectors on it instead of the poppet valves.
Another option you could go with is converting it to the marine intake manifold off of the mercruiser 4.3
It has a real fuel injection setup instead of those stupid spiders, its pricey to do though but it would give you upgrade potential in the future.
Or you could just ls swap it...........
34 minutes ago, Broke_Audio_Addict said:
Yep, they sure are.
This... all day this. There is a upgraded one out there. If your that deep into it, the DO THAT,.. Thats what cured all my misfire stuff. It ran so damn well. Entire different car, better milage, idled so damn good. Was a completly different car. Again, i dont know, if it is it, but, i heard its common, and after dropping coin, and time on the old, plugs wires, cap rotor shit for a month, this shit cured the fuck outta it,... engine light went off, code (misfire cyl 3) reset and stayed off, and like i said, it ran fucking awesome.
  • Who's Online   0 Members, 0 Anonymous, 3773 Guests (See full list)
