first time trying to build a box
rsfm089
Thank you will this box also work off of a thousand watts till i get a new amp or should i wait to build the box. well i have to draw it up.
Running less power in an enclosure meant for more power will be fine. The effects will not be harmful to performance as they would be if the power was more than the enclosure was designed for
how do i figure out at cut sheet.  Trying to draw it up and i thought with 3 common walls i would want the port to be 4.75 continuously but i don't know where the third wall would start. i hope that make sense.
3 common walls means the port has three walls in common with the sides of the box.  It doesn't mean the port needs to be make from three panels.
2 minutes ago, rsfm089 said:
Does this look right every square is equal to an inch well don't know how to upload a picture damn it
I use imgur.com for pictures.  It works well.
Builds:
That looks pretty good, but your port is only about 36" long.
Builds:
will fix it read physical port length instead of port length thank you very much going to start building tomorrow. Once again thank you very much. hope someone makes a program for mac one day
On 10/19/2012 at 5:30 PM, Joe X said:
Download this spreadsheet:
https://docs.google.com/spreadsheet/ccc?key=0AsFyH9hGFoZydE9TaThIeGdTd3Nib1ViWm54NnNkWGc#gid=0
You need to download it for it to be editable, go to file, download as, and then choose a format (like .xls), its very accurate, it does everything that Torres does and is very accurate.
Maybe this is still good and accurate? Got it from another thread where someone asked about a mac program
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
