giusiwa Posted August 4, 2017 Report Posted August 4, 2017 Hi, i'm designing a box for my zv5 15", i've do a project with google sketchup but i don't know if my design is good or not(i leave the google sketch project). I've do my project Seeing this video: box parameters: net cu.ft= 4,25cu.ft tuning freq=32hz W(28,74") - H(21,5") - D(20,75")=OUTER DIMENSIONS driver displacement= 0.25 cu.ft port displacement= 1,57 cu.ft port dimension = W(3,4") - H(20") - LENGTH(33.6")(carstereo.com) my question is: IS GOOD THIS TUTORIAL?IN WINISD THE PROJECTS CHANGES (the port length is different on winisd) For this reason I am doubtful on my design. Can you eventually crete your own design if my box is not good? PS 1x sundown zv5 15.skp
Triticum Agricolam Posted August 5, 2017 Report Posted August 5, 2017 That looks pretty good. How much power are you going to be running? You probably want to add a second baffle and bracing for strength. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
giusiwa Posted August 5, 2017 Author Report Posted August 5, 2017 thank you ; ) i give to the sub around 2400w rms @1ohm, the box that i designed is good?
Triticum Agricolam Posted August 5, 2017 Report Posted August 5, 2017 Yeah, that should be fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
