Port tuning help
Fennygolf
So I build my encloser have 2 DC audio xl m1 15s the encloser is around 6.26 cubes and from the math I did which is probably wrong I put in 6 2inch long 1-1\2 diameter PVC pipes and I thought my tuning came out to 31-32hz but for some reason is only wanting to play from around 40hz and up can't figure out why anyone have any ideas or did I do my math wrong please help
You have 1.5" diameter pvc ports? Even 6 of them is nowhere near enough port area
05 TL build log SOLD
What amp are you running?  How much port area you need is influenced by how much power you are running.
Builds:
14 hours ago, Fennygolf said:
im running 2 audiopipe apsm 1500s at 1ohm each
Ok, so lets figure 3,000 total watts max.
On that amount of power one 10" diameter port would work very well.
Or you could use three 6" ports, the single 10" would preferred though.  Two 8" ports would also work, but they are a bit bigger than you need and would have to be pretty long.
Or you could use a slot port of at least 85 sq in.
Builds:
3 hours ago, Fennygolf said:
okay how long would the 6inch ports have to be
Are you going to have the ports inside the box or outside?  I ask because if you put the ports inside the box they are going to take up significant internal box space, which will affect the tuning frequency.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 1416 Guests (See full list)
