not to be blunt but ummmm....... to the frame, as short of a run from the battery  and the alt as possible
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
I did a quick Google search and found this article.
http://tahoeforum.com/showthread.php?t=7828
But the pics are not there anymore like most older thread's
Basically like tboorm said. Grounds should be near battery.
If you don't know if the part you want to ground to is good or not you can use a volt meter to check continuity with + probe on battery + and - probe where you want to ground.
Once you know the part you chose connects to the battery now turn to your resistance setting on your multi meter ( measured in ohms ) and look to make sure it's less than .3 try to get lower if you can. I used where my stock wires grounded in my Civic and it works great but they're less than a foot away already.
