knowledge Posted April 30, 2008 Report Posted April 30, 2008 ok, so i have 2 rockford bd1000 amps in a master sleave setup, powering 2 12 inch dd 9500 witch are .7 ohms each doul voice coils, i wired all the positives together and the same with the negetives witch is a little over 2 ohms each i think, so my question is, is it possible to wire each sub to each individual amp down to a 1 ohm load or so with out the master sleave and get all the power from both amps???? Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
banginAltima Posted April 30, 2008 Report Posted April 30, 2008 (edited) Whoa.... all positives and all negatives is a VERY BAD THING!!!!! If each coil is .7 then you just wired each sub down to .35 ohms, Rockford amps can't take that... If each coil is .7 there is no way to get 1 ohm out of each sub. You need to wire each coil in series (positive to negative) and subs in series and strap the Rockfords with the bd sync cable. Edited April 30, 2008 by banginAltima Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
knowledge Posted April 30, 2008 Author Report Posted April 30, 2008 Whoa.... all positives and all negatives is a VERY BAD THING!!!!!If each coil is .7 then you just wired each sub down to .35 ohms, Rockford amps can't take that... ooops i ment i wired each sub positive to negetive and then the rest to the amps so basically each sub is not getting all the power of the amps witch is what im trying to do? Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
knowledge Posted April 30, 2008 Author Report Posted April 30, 2008 (edited) can anyone help with this, is there any othere way to wire this setup? Edited April 30, 2008 by knowledge Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
banginAltima Posted April 30, 2008 Report Posted April 30, 2008 you need different amps or different subs Quote If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
knowledge Posted April 30, 2008 Author Report Posted April 30, 2008 what if i wired 1 sub to 1 amp down to 1 ohm or so, wont i get more power out the amp that way than wireing both subs togerther? you get what im saying? Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
mylows10 Posted April 30, 2008 Report Posted April 30, 2008 what if i wired 1 sub to 1 amp down to 1 ohm or so, wont i get more power out the amp that way than wireing both subs togerther? you get what im saying? if your amps are 1 ohm stable you can use the pass thru and used each amp on each woofer, Quote dc 12k 2 ascendant mayhem 12s xs power 200 amp alt 2 odyessy pc 2150 dc audio 175 x 4 scosche wires stinger inter connects 12 volt customs 175 amp alt pioneer avhp 4100 dvd arc audio eq cdt 6.5 components 152.8 db drag street c http://www.dcsoundlab.com/ //www.dcsoundlab.com/images/header.jpg
wL<3bass Posted April 30, 2008 Report Posted April 30, 2008 (edited) what if i wired 1 sub to 1 amp down to 1 ohm or so, wont i get more power out the amp that way than wireing both subs togerther? you get what im saying? Okay lemme break it down for you....if you wire one sub with dual .7 ohm vcs in series you get 1.4ohm in parallel you would get .35ohm a piece. edit: 1.4ohm would work for daily but it wouldn't be enough power for a 95 series. Edited April 30, 2008 by wL<3bass Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
wL<3bass Posted April 30, 2008 Report Posted April 30, 2008 (edited) I would put one amp on each vc....as long as you have the electrical to support it. So I believe you said you have 2 subs then you need 4 t1001bd Edited April 30, 2008 by wL<3bass Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
knowledge Posted April 30, 2008 Author Report Posted April 30, 2008 i only have 2 t1000 for now but im just going to put one amp to each sub with the pass thru aption, would i be getting a bit more out my amp that way than wireing both subs together and strapping the amps? Quote REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
