Rockford Amp
knowledge
ok, so i have 2 rockford bd1000 amps in a master sleave setup, powering 2 12 inch dd 9500 witch are .7 ohms each doul voice coils, i wired all the positives together and the same with the negetives witch is a little over 2 ohms each i think, so my question is, is it possible to wire each sub to each individual amp down to a 1 ohm load or so with out the master sleave and get all the power from both amps????
REFF'S
My link
EBAY
Whoa.... all positives and all negatives is a VERY BAD THING!!!!!
If each coil is .7 then you just wired each sub down to .35 ohms, Rockford amps can't take that...
If each coil is .7 there is no way to get 1 ohm out of each sub. You need to wire each coil in series (positive to negative) and subs in series and strap the Rockfords with the bd sync cable.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
ooops i ment i wired each sub positive to negetive and then the rest to the amps so basically each sub is not getting all the power of the amps witch is what im trying to do?
REFF'S
My link
EBAY
can anyone help with this, is there any othere way to wire this setup?
Edited by knowledge
REFF'S
My link
EBAY
you need different amps or different subs
I do box designs.
what if i wired 1 sub to 1 amp down to 1 ohm or so, wont i get more power out the amp that way than wireing both subs togerther? you get what im saying?
REFF'S
My link
EBAY
if your amps are 1 ohm stable you can use the pass thru and used each amp on each woofer,
dc 12k
2 ascendant mayhem 12s
xs power 200 amp alt
2 odyessy pc 2150
dc audio 175 x 4
scosche wires
stinger inter connects
12 volt customs 175 amp alt
pioneer avhp 4100 dvd
arc audio eq
cdt 6.5 components
152.8 db drag
street c
http://www.dcsoundlab.com/
//www.dcsoundlab.com/images/header.jpg
Okay lemme break it down for you....if you wire one sub with dual .7 ohm vcs in series you get 1.4ohm in parallel you would get .35ohm a piece.
edit: 1.4ohm would work for daily but it wouldn't be enough power for a 95 series.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
I would put one amp on each vc....as long as you have the electrical to support it. So I believe you said you have 2 subs then you need 4 t1001bd
Edited by wL<3bass
My YouTube Videos
i only have 2 t1000 for now but im just going to put one amp to each sub with the pass thru aption, would i be getting a bit more out my amp that way than wireing both subs together and strapping the amps?
REFF'S
My link
EBAY
  • Who's Online   0 Members, 0 Anonymous, 2029 Guests (See full list)
