I got off of work after working a 13 hr shift. Get out to my truck and open my door and an extremely high pitched noise is coming from my system. The key is not in the ignition and nothing is on yet there is a noise. At this point I am freaking out. So I get my tools out and start disconnecting stuff. The big amp, then when I disconnect the cap from power (or ground? not sure, was dark) the noise faded away. What could of caused this and this is the first time it's happened.
yeh my old pro ice caps peeped below 10 volts.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
my cap does it when i disconnect it from the battery. It lets u know the voltage is to low. What kind is it
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
sub:2 DC lv4 12
Caps are really weird sometimes, they do some crazy stuff on occasions...
Agree, We were in my buddies car one time and we are looking at his system and it just turned on for no reason and started to blink and then turned off 5 seconds later. I was like ummmm wow. We dident even touch anything, Thought it was an omen or something. Does the cap help your system at all? and what farad is it?
It's a Tsunami 5 Farad cap. Worked fine all the way up until I opened my door to that ungodly high pitched noise. Constant to not beeping.
thats the same one i have so its the voltage going to low take a meter and c what the cap is resting at
sub:2 DC lv4 12
maybe something was draining your battery while you were working all day and the light coming on when you opened your door made it drop enough to beep / whine.
  • Who's Online   0 Members, 0 Anonymous, 4539 Guests (See full list)
