Under hood batteries enough?
I have 2 stock batteries in my 2011 6.7 f250.  Going to be running a 3500 sub amp and whatever my door speaker amp will be.  I’m guessing around a lil over 4Kish power.  Any idea if I upgrade my batteries to some decent AGM batteries that would suffice?  Or am I looking at a upgraded alt as well and extra batteries?
I have 3 xs power 3100s but there way to big to fit under the hood and just trying to justify the need of them anymore.
What kind of alternator power do you have to feed that gear?
'07 Ford Ranger - DM-608 I E700.4 I SA-CX6.5 v2 I SAZ-1500D 15th (x2) I Zv6 12" D1 I SB500-34 I JP40 I
On 5/21/2015 at 7:07 PM, boom50cal said:
of course he gives no fucks. it's a ford ranger.
only bad mother fuckers drive ford rangers
15 minutes ago, Sky said:
  Alt upgrade and 2 agm batteries under hood?
That plus a couple of runs back to some dual inputs on the sub amp and i would say you'd be ok.
Just my opinion based on my knowledge though.
There are other variables that if you could provide would help get more/better advice. Such as what amp? planned intended final impedance amp will see?
Soundqubed 3500 at 1ohm.
I was originally thinking of hooking up my 3 3100s in a toolbox in the bed.  But just don’t think I need 5 batteries in total. For only about 4.5k of power.
I'm running what could basically be described as a scaled down version of what you have planned, about 2400w total (rated). I have a 250A alternator with three group 65 batteries, i very rarely see anything below 13.8v.It's probably overkill but i'm fine with that.
You might be best off with a HO alt and the three AGM's, two under hood and one closer to your sub amp.
