dimondntr2004 Posted March 27, 2018 Report Posted March 27, 2018 I have a 2010 tahoe. max dementions 39 long x49 width x 23 high. the subs are 4 18 fp4 v1s. powered by 2 Orion hcca 5000.1d spl amp.
dimondntr2004 Posted March 30, 2018 Author Report Posted March 30, 2018 I had the crazy idea this was the forum for help. max dementions 40x49x27 can I please get help
bcbrassard Posted March 30, 2018 Report Posted March 30, 2018 Some guys just give complicated advice, use to be a guy that gave solid designs out fast but he doesn't post much anymore. But someone will help steer you in the right direction, just give it time.
Triticum Agricolam Posted March 30, 2018 Report Posted March 30, 2018 You don't have enough room for four 18"s, its not even close. You have plenty of room for two 18"s though. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
dimondntr2004 Posted March 30, 2018 Author Report Posted March 30, 2018 I have 49x40x27 that' not enuff for 5cubes each?
Triticum Agricolam Posted March 30, 2018 Report Posted March 30, 2018 1 hour ago, dimondntr2004 said: I have 49x40x27 that' not enuff for 5cubes each? No, it isn't. You don't even have enough room to give the subs 4 cu ft each. With a box that size, and with the amount of power you are going to be running, you are going to want to double layer the walls. That gives you 23.64 cu feet of gross internal space, the subs take up a little over 1 cu ft, a port big enough to handle the power you have is going to take up around 7 cu ft. That already puts you under 16 cu ft of net airspace left. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
dimondntr2004 Posted March 30, 2018 Author Report Posted March 30, 2018 ok so anything I can do for it to work
Triticum Agricolam Posted March 31, 2018 Report Posted March 31, 2018 53 minutes ago, dimondntr2004 said: ok so anything I can do for it to work Get 15"s instead of 18"s, or run less subs. Three 18"s would fit, but that's going to be less than ideal to power with two amps. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
