Need help asap!
Hi Joe,no vehicle involved.this is a home audio set up.the only issue here is it needs to be 24" tall and 18" deep max.thanks for your response.almost forgot,I'd like the port forward facing same as sub.thanks again.
So here is a suggestion, the round port needs to turn so an inexpensive fitting would be needed:
Unhappily you can't, a 3" port is only about 7 square inches of port area, you would need 4 of them but even if you could your 4 ports would be a less efficient setup than a single 6".
  • Who's Online   0 Members, 0 Anonymous, 1209 Guests (See full list)
