Ernest Posted April 6, 2018 Report Posted April 6, 2018 8cf box, port 4”high x38”wide x20”long for team fi 18 on a scv4000. Have extra battery’s stock 140 alt. So sub prob seeing maby 2k out of the amp. question is will this port be noisy concedering it being 4”x38”
Triticum Agricolam Posted April 6, 2018 Report Posted April 6, 2018 That should be enough port area. What's your intended tuning frequency? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
WalledSonic Posted April 6, 2018 Report Posted April 6, 2018 3 hours ago, Triticum Agricolam said: That should be enough port area. What's your intended tuning frequency? Even tho its enough port area, does the increased surface area in the port due to the 10:1 aspect ratio cause more friction? Is there an aspect ratio you recommend in general for slot ports? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Triticum Agricolam Posted April 7, 2018 Report Posted April 7, 2018 3 hours ago, WalledSonic said: Even tho its enough port area, does the increased surface area in the port due to the 10:1 aspect ratio cause more friction? Is there an aspect ratio you recommend in general for slot ports? The high aspect ration certainly isn't ideal. I like to keep aspect ratios under 5:1 if possible and 8:1 is my absolute upper limit. Increasing port area can compensate for an undesirable aspect ratio. In the OPs case, he has enough port area it shouldn't be a problem. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Ernest Posted April 7, 2018 Author Report Posted April 7, 2018 8 hours ago, Triticum Agricolam said: That should be enough port area. What's your intended tuning frequency? Shooting for around 32ish hertz
Ernest Posted April 7, 2018 Author Report Posted April 7, 2018 1 hour ago, Triticum Agricolam said: The high aspect ration certainly isn't ideal. I like to keep aspect ratios under 5:1 if possible and 8:1 is my absolute upper limit. Increasing port area can compensate for an undesirable aspect ratio. In the OPs case, he has enough port area it shouldn't be a problem. Yes the high aspect ratio is a problem that I am concerned about. What are the negatives that I should expect from it being that high? Will it cause port noise, or just loose a bit of output due to the higher surface area...”are the sparks going to ignite the fumes or my dust cap going to twist”?
