Basshead2008 Posted May 1, 2008 Report Posted May 1, 2008 Just wanting everyone's input on which works better. A battery or a capacitor? I already have a 10 farad capacitor to run it so can I just add a battery, or do I need to toss the cap and install battery alone? Also what is that thing called that you use to split your power cable to 2 seperate amps, and also what I use to split RCA's to 2 seperate amps? This is my first time using multiple amps. Howard A.K.A.- Ol' Mater Current systems Speakers: -2 15" Kicker Comp VR -4 15" Lanzar ProMax -2 Kicker comp 6.5's -4 infinity tweeters Amps: -1 HiFonics 750w mono -1 Kicker 550.1 -1 Lanzar Vibe 2ch 2000w -1 Legacy Predator 2ch 2000w Items I have bought for new builds: -2 Kicker Solo X 18's -2 Kicker Solobaric L7 15's -2 HiFonics Xx Goliath 5000w Monoblock Ultra D class
Noobtastic14 Posted May 1, 2008 Report Posted May 1, 2008 With the RCAs your going to want to have two different runs from the back of your HU if that is not an option you can get "Y" splitter cables for your rcas that will work fine as well. for power and ground wires you can get a distro block that works with your size wiring. if it were my setup i would add the bat and ditch the cap -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
Kicker Guy Posted May 1, 2008 Report Posted May 1, 2008 basically yes to everything he said.... but you already bought the cap... might as well use it Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
Basshead2008 Posted May 2, 2008 Author Report Posted May 2, 2008 basically yes to everything he said.... but you already bought the cap... might as well use it ok sounds great, how would i wire the battery and the cap together? Howard A.K.A.- Ol' Mater Current systems Speakers: -2 15" Kicker Comp VR -4 15" Lanzar ProMax -2 Kicker comp 6.5's -4 infinity tweeters Amps: -1 HiFonics 750w mono -1 Kicker 550.1 -1 Lanzar Vibe 2ch 2000w -1 Legacy Predator 2ch 2000w Items I have bought for new builds: -2 Kicker Solo X 18's -2 Kicker Solobaric L7 15's -2 HiFonics Xx Goliath 5000w Monoblock Ultra D class
07sOnAtA sp.ed Posted May 2, 2008 Report Posted May 2, 2008 id go battery http://www.sonicelectronix.com/cat_m162_i2...-isolators.html CURRENTLY UNDER RE-CONSTRUCTION 2008 Hyundai Sonata Team T3 Audio Team Deadly Hertz Team SMD (Street Motivated Devastation)
Stremes Posted May 3, 2008 Report Posted May 3, 2008 Wire the capacitor in parallel with the batteries. And i would use both. Have a power wire running from the battery into a distribution block and have another one running into the capacitor and then into the distribution block. That way the amp can pull from the batteries and the cap at the same time. I once followed the instructions on a Power Acoustik cap and ran it in series with my battery.. didnt work out to well, fried the cap PS: as for batteries any deep cycle battery will do just fine.. same with marine/RV batteries, i have them and work great 2 Orion HCCA 15.4's half wall setup with backseat out 3cf per chamber tuned to 35Hz 145.3DB @38Hz in DB Drag Super Street 1-2 Rockford T30001BD Hifonics BXI 1006 2-channel 200amp alternator 0ga welding cable power & ground (the big 3) Two runs of positive Optima RedTop upfront 2 Interstate SRM-27 marine batteries in trunk JVC deck and Phoenix Gold line driver Rockford Fosgate T162C in front doors Rockford Fosgate T162C in custom fiberglass pods Rockford Fosgate T1692C in stock location More fosgate component speakers to come
