Component speakers use a hpf or run full range
tbeats
Have a set of focal 165 krx2 components should you use a hpf or just run full range? I’m running the passive. The crossover has a hpf option and full so I take it full is safe?
Well if the deck is capable of doing a HPF then run the HPF off the deck an not the amp, that way you have more control and more set points.
73456w9vbwevsdb
sodtbsorutnvsd
sdtuspdun sd d
f gsdfiusd gdf n
Using the passive crossovers you will want to set it for full range or you will cut off lower frequencies.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
