Project GP No Sag Springs (750lbs+) on the Camry
My $400 GP Car Audio No Sag Springs has arrived today. It took a while to get here due to some mix-ups at their facility but they took care of me and gave me $50.00 store credit so all is good.
I'll post some more videos of the assembly process later and the install. I had to place an order on Amazon for the KYB SB101 Bumper Stoppers. I hope these Spring Compressors can handle these 700lbs+ GP No Sag Springs.
Bro if those dont work out, you can get springs cheap from BC Racing. $136 per pair shipped. I sized my first set wrong (my fault on spring rate prediction), but the second set is perfect. 4kg/mm spring rate is just right for mine.
IG @walledsonic
If I had known I would have gone with them :(
Would you just give them an estimate of how many lbs above stock weight you'd want to bring car back into stock height and they make the spring for you base on that? or do you need to know the exact spring rates and what not?
Yes except they just select a spring out of a catalog that suits your requirements.
Sizing/fitment is always an estimate unless you take measurements of your spring deflection AND know the spring rate.  Since I knew the unsprung height and spring rate of the first set I ordered, I measured the sprung height and did some simple calcs to come to the correct height with a slightly softer rate.  Currently happy after the second set. Still worth it IMO.
IG @walledsonic
The damn KYB bumper stopper barely fits into the bellow rubber cover on the strut so I had to put the bump stop at the bottom (normally they're at the top I think).
Hopefully the bellow cover doesn't move up over time leaving the strut piston exposed.
Install is done.
My ABS light in the dash is on :(
I am guessing I over extended the ABS wire during the strut install. Any advice on how to trouble shoot where the potential short circuit might be...
What I noticed about these springs was the GP Car Audio No Sag Springs had more coils than the stock. My ride height at the rear is at like 28" though. Is this normal? I ask this because they originally had some mixups at the warehouse with my stuff and had to speed production these for me.
  • Who's Online   1 Member, 0 Anonymous, 783 Guests (See full list)
