77-AUDIO Posted June 6, 2018 Report Posted June 6, 2018 Has anyone used the idatalink for 2008 dodge ram trucks. and can it be used to connect to the obd2 port PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
JRsmoothee Posted June 6, 2018 Report Posted June 6, 2018 i have one installed on my 09 grand cherokee...works great...obd2 port connection is neat feature, but kinda pointless in my application
77-AUDIO Posted June 6, 2018 Author Report Posted June 6, 2018 how is the obd2 connection made. is it a plug in or do you have to wire it up. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
lightfoot Posted June 6, 2018 Report Posted June 6, 2018 it makes its communication through the can bus system in the vehicle. there is no physical connection to the obd port
JRsmoothee Posted June 6, 2018 Report Posted June 6, 2018 37 minutes ago, lightfoot said: it makes its communication through the can bus system in the vehicle. there is no physical connection to the obd port yes there is.....its a harness that plugs into the idatalink and then plugs right into obd port...
77-AUDIO Posted June 8, 2018 Author Report Posted June 8, 2018 See I have seen both, but on one of the harnesses there are 2 unused wires and then on others the same wires connect to a plug that connects to the obd port. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
JRsmoothee Posted June 8, 2018 Report Posted June 8, 2018 well get the one for your specific vehicle... and make sure it has the connector for obd...problem solved
77-AUDIO Posted June 8, 2018 Author Report Posted June 8, 2018 Well I called them to ask about the wires, and the old style you had to tap into the obd2 wires, and the new plugs have the wires connected to a plug that connects directly into the obd2 port. but I have to login and flash the unit fir the specific vehicle which is cool it reduces cost and can be used for any vehicle. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
