shredder2 Posted July 7, 2018 Report Posted July 7, 2018 It all depends on the size of the 45's... 4 ea 3" 45's and a dowel, all 12.5" tall = .08ft3 roughly Thats 2.12 2.12 x H for a set (2) of 3" ... 4 ea. 4" 45's and a dowel, all 12.5" tall = .13ft3 roughly That's 2.86 x 2.86 x H for a set (2) of 4" Dowels are easy... same as finding the area of a circle then volume of a cylinder... Pi X radius2 x Length. In this case using a 1.5" dowel it's 1.76 .(75 x .75 x 3.14) X 12.5 (L)... that ends up as .012ft3 Helps a bunch when you've done it awhile and the values are automatic... lol
DiBo Posted July 7, 2018 Report Posted July 7, 2018 3 hours ago, shredder2 said: It all depends on the size of the 45's... 4 ea 3" 45's and a dowel, all 12.5" tall = .08ft3 roughly Thats 2.12 2.12 x H for a set (2) of 3" ... 4 ea. 4" 45's and a dowel, all 12.5" tall = .13ft3 roughly That's 2.86 x 2.86 x H for a set (2) of 4" Dowels are easy... same as finding the area of a circle then volume of a cylinder... Pi X radius2 x Length. In this case using a 1.5" dowel it's 1.76 .(75 x .75 x 3.14) X 12.5 (L)... that ends up as .012ft3 Helps a bunch when you've done it awhile and the values are automatic... lol Man good shit. I need to get off this mentally lazy spell haha. I swear I've been guessing displacement for my bracing ( scientifically of course ??). I round down tho so... LMFAO!
GorillaFIngeRs Posted July 8, 2018 Author Report Posted July 8, 2018 how would port area requirements change if I went aeroport? still 15-17cuft per cube? AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted July 8, 2018 Author Report Posted July 8, 2018 Ok so I think this should work out pretty good I did calc's with and without bracing. I will add that if needed. This double baffle should hold up just fine. Im using maple. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
shredder2 Posted July 8, 2018 Report Posted July 8, 2018 23 minutes ago, GorillaFIngeRs said: Ok so I think this should work out pretty good I did calc's with and without bracing. I will add that if needed. This double baffle should hold up just fine. Im using maple. Not bad... see post 21 for bracing displacements... a touch low on port area on your power but you'll probably never notice... Nike it!
GorillaFIngeRs Posted April 13, 2019 Author Report Posted April 13, 2019 Thanks for all the info last year ya'll. I have decided to rebuild, go with more port area, box sounds great just time for a change. Did decent numbers with this setup but peaking higher then I would like. I am looking for some more suggestions, would like to really feel the lows. I swear this corolla his tough af to get loud. Now weighing my options between aeroport and slot port. I can fit 14.75Hx35Wx26D max. I have thought about port facing back the width of the box but maybe im missing something. Cant achieve port area and tuning that I want. Fi recommended 65-75in I'm shooting for 32hz or lower. prefer lower if possible. Thanks for any info guys! Still on AQ3500.1, dual input version AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
