AB xfl12 and db16
ehall8702
I have 4.5-5 cubes to work with, only a single 12 and about 2k rms. I currently have my sub facing backwards slot ported @36hz. Port width is 2.5" . It's in my 98 Blazer. I want to build a new box to optimize my output. Should I face the sub and port up? Sub up port back? Also, if a slot port is the best way to go, how wide should my port be? I think 2.5" isn't enough, low notes kinda chuff a bit. So , how low should I tune and how wide should I make my port ? This thing moves alot of air and I'd like to get the most spl I can out of my current setup.  It's a xfl1224 ( whichever is a dual 4 ohm ) . Any help would be awesome. Eventually I will get a second sub and second db16 but for now want best I can get from what I got. Thank in advance for the help!
Yeah i read that info before. I'm not building a cube box though, going to use the whole back of my Blazer behind the rear seats. Just was wondering if anyone had any experience with maybe a wider port or something that would give me a bit more output. I'm leaning twords sub up and port up or back. Want it to look like it's all box and one piece I guess. Kinda similar to SMDs Tahoe setup. Probably going to get a second sub and amp soon so I'll build the box for both subs with a divider in the middle so I can continue to use my single sub for now.
Alot of people like sub up, port back in those blazers.
Had a 95 blazer 4 door. It saw everything from 2 10s, 6 12s, 4 15s.... always preferred subs and port back myself. Sub up made the roof rattle more, may have been better on the meter, but to the ear it was quieter than sub/port back.
Sub and port about 6 inches from the rear tailgate usually worked best for me.
05 TL build log SOLD
So specs airspace and aeroprts back, what diameter aeroport should I use? A 3" or 4" and what should I tune to? 36 hz now and it missed some of the lower notes as it is. Maybe 32 or 33hz? And thanx guys for the input, I appreciate it .
And doubt it matters but I have a 2 door blazer
https://youtu.be/ZbNcR8vEa9I
Took a quick video of my blazer
  • Who's Online   1 Member, 0 Anonymous, 1568 Guests (See full list)
