DiBo Posted September 4, 2018 Report Share Posted September 4, 2018 Seen a post where somebody said it was a great combination. Any truth to this? Looking into lithium Link to comment Share on other sites More sharing options...
WalledSonic Posted September 4, 2018 Report Share Posted September 4, 2018 AGM pulls your system voltage down a very small amount, basically miniscule. Ive ran AGM under the hood and lithium in the back for about a year or so. No complaints. I keep the AGM under the hood bc this is my daily driver and sometimes I have to do maintenance, so I disconnect the lithium in those instances. And, in the rare case I have to take my car into the shop (almost never), they wont have the opportunity to fuck up my lithium. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
DiBo Posted September 4, 2018 Author Report Share Posted September 4, 2018 What lithium are you running. Any heads up I needed to be concerned with? I have access to some pretty good priced cells..40ah fir $381 You told me once already but what alt are you running? Link to comment Share on other sites More sharing options...
WalledSonic Posted September 4, 2018 Report Share Posted September 4, 2018 Running JY although I hear good things about Limitless. Seen the build quality in both so I think its a crap shoot. A lot of guys are doing DIY lithium nowadays. I would consider building my own bank, but I wouldnt buy a homemade bank unless every fucking connection was video'd or visible thru acrylic case or something. Nothing to be concerned with really. 13.3V rest. Dont charge over 15V. Plug and play. Running a Mechman 320A currently. Does the job, same parts as most HO alts (maybe even cheaper parts than most, honestly. Singer and US have nicer rectifier, diodes, and connections). Although, it makes 316A HOT AF and continuous after an hour of demoing, and about 167A continuous at idle. I recommend a large case hairpin if you can afford it. Theres some alt builders that inflate the ratings a bit and dont make large case alts. Someones gonna reply with 'my small case works just fine'. And it does, but it just doesnt do shit at idle. I like to be able to set the system to demo mode and step out of the car and not worry about the alt speed. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
DiBo Posted September 5, 2018 Author Report Share Posted September 5, 2018 36 minutes ago, WalledSonic said: Running JY although I hear good things about Limitless. Seen the build quality in both so I think its a crap shoot. A lot of guys are doing DIY lithium nowadays. I would consider building my own bank, but I wouldnt buy a homemade bank unless every fucking connection was video'd or visible thru acrylic case or something. Nothing to be concerned with really. 13.3V rest. Dont charge over 15V. Plug and play. Running a Mechman 320A currently. Does the job, same parts as most HO alts (maybe even cheaper parts than most, honestly. Singer and US have nicer rectifier, diodes, and connections). Although, it makes 316A HOT AF and continuous after an hour of demoing, and about 167A continuous at idle. I recommend a large case hairpin if you can afford it. Theres some alt builders that inflate the ratings a bit and dont make large case alts. Someones gonna reply with 'my small case works just fine'. And it does, but it just doesnt do shit at idle. I like to be able to set the system to demo mode and step out of the car and not worry about the alt speed. A lot of useful info. Thanks man Link to comment Share on other sites More sharing options...
Blower Audio Posted September 8, 2018 Report Share Posted September 8, 2018 Though it may not be immediately detrimental and end in a ball of flames, I definitely recommend isolating your lithium and AGM. That way you don't have to worry about parasitic draw between them and their different open circuit resting voltages. You will only prolong the life of your batteries by isolating them properly from one another. Link to comment Share on other sites More sharing options...
