need box design for 4 SA-15's
02Blazer
 i need a box design for 4 SA-15's , will be running it off an Orion XTR2500 , it's for a 2002 chevy s10 blazer , Joe X designed a box with the port going across the bottom , would like the same design (subs up, port back, tuned around 35 hz.
my dimensions i'm working with are 37'' width 20-21'' height and hopefully depth is 50'' or less.
thanks so much
edit ; if the 4 Sa 15's dont work in that space , i will opt for 2 Sundown X 18's run off that same amp
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:
Any changes let me know.
  • Who's Online   0 Members, 0 Anonymous, 4258 Guests (See full list)
