well, this is my first system but is my second box build (actually third-due to some of my faulty measurements the second box didnt fit-glad i test fitted before i finished it :-[) anyways here we go...
under the hood...
new iraggi 200 amp alt.
i managed to somehow sqeeze a nsb 90 under the hood of my 92 accord...
big 3 upgrade with 1/0...all soldered
by the way...this electrical is overkill for the size of my system imo...but i need room to upgrade in the future ;D..
some fugly battery terminals i made out of 1/4" copper...ugly, but get the job done..
onto the box...
about 5.7 cubes...5cubes after all displacement. i planned on doing swappable ports--(2) 4"aeros for daily tuned to 32 and a square port tuned to about 50 for comps (which i still have to remake)
here is the sqare port. i gotta remake it still (been a real lazy ass this summer) but u get the idea..
the aeros...dont worry i used some plastic glue and then duct taped them
here is the box covered in resin...i had to resin the outside because of a small leak in my trunk i cant find...didnt want the wood getting wet
decided to use some 1/4" insert nuts for the swappable ports...
test fitting the port and subs
first time at a carpet job...the only side that needed to look decent was the front...and it does, so it works for me
now this box was an absolute bish to get in my trunk...barely fit...here it is and my amp..and i know my wire is pinkish and pupleish...the company f'd up on that, but they also accidently sent me double the wire i ordered and didnt charge me for it, so i didnt complain...i ran 1/0 wire straight to the amp through some stinger gauge reducers. i also recarpeted the port since this pic so no wood is showing..
this box has been done for awhile and for some reason i still cant make myself finish it up by sealing it off from the trunk, even though i need to....maybe i will eventually get around to it...lol
i likes me some audio stuff...
those RE amps are Sexxxxxxxxxxxxy
nice job on the build, I will tell you from experience SEAL that fugger offf and  you will  ;D ;D
thanks guys...and i know i should seal it off, just been too lazy. i had the last enclosure sealed off and it wanged. hopefully if i ever get off my lazy ass and seal it off it will get rid of some of this trunk rattle i got goin on and add some bass... ;D
  • 4 weeks later...
