bs bs bs bs bs
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
just looks like a random generic sub,
Inferno-12DVC
Dual 1 or 2 Ohm Voicecoils  Let us know
Dual 100 Oz Magnets Inside a 30 pound Motor Structure
Power Handling: 1800 Watts rms, 5000 Watts Peak
--Mechanical Parameters--
Fs= 30.32 Hz
Qms= 4.90
Vas= 54 liters
Cms= 0.125 mm/N
Mms= 212 g
Xmax= 18 mm
Xmech= 30 mm
Sd= 0.055 sq.M
--Electrical Parameters--
Qes= 0.289
Re= 1 ohms/ coil
BL= 12.02 Tm
Perms= 1200 watts
Ppeak= 5000 watts
--Electromechanical Parameters--
Qts= 0.273
SPL= 91.76 dB
compared to the 06 XXX thats easily had for 600 bucks
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
