Any benefit of running ground from front to back?
Is there a benefit to running grounds from front battery of vehicle to rear battery bank? All I can see is a nasty ground loop compared to frame and chassis grounds. I've seen it done before and actually pulled 2 different setups out of friends vehicles just because it goes against everything I know about 12v systems. Any input would be awesome,  I don't see myself doing this in my truck, but if it actually has a REAL benefits I may consider it in the future.
A unibody is only good up to a certain amount of amperage. At some point you wont have a choice but run grounds. A car with a frame? Just use the frame
So I've got a real frame and intend on front and rear both getting a bolt through the frame as a ground. I'm about 2800 rms and not gonna be upgrading anytime soon.  I should be good right? And if I add another amp and sub I'd need to run double runs of ground at that point I'm sure.
That sounds good. Just make sure to clean the frame up where you're going to pop put the bolts. Shiny metal is good metal :slayer:
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
