ehall8702 Posted February 10, 2019 Report Posted February 10, 2019 Looking for a budget amp for under $250. Sold my Rockville db16 installed for that and now need another amp. I have been looking for something 2k ish or more. For now gonna run 2 vfl8s@ either 1 or 4 ohms, and will be getting another pair of vfls soon, so the 1/2 ohm stable on this amp makes feel this is a good choice. Ppi used.to be good equipment, have no idea if it still is. I like the looks of.it also. Watched it on the dyno and it put up good number, very close to rated. Had the a few American bass amps on my list also but theu dont seem to put out rated numbers from.the dynos i watched. I know im way over powered for the subs i have but i may end up running something different amd would rather have plenty of overhead and plenty of power for whatever i want to run in the future. Whats yalls input on this amp or suggestions on a good amp under 250 that over 2k @..5 ohms or 2k at 2ohm. Never had a problem with my Rockville, they have great customer service and good warranty but just want something different as they dont look that great. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
bmwking Posted February 10, 2019 Report Posted February 10, 2019 eh i'd stay away from it, the low end (if not all) PPI stuff is trash nowadays. personally, i have one of these beating the hell out of 2 xfl 12s right now. according to the amp dyno is only does about 1.8k rms but it's definitely putting in work for me. https://www.amazon.com/American-Bass-Amplifier-Phantom-Micro-Technology/dp/B0096BAS10 also, bigD did a dyno drag with a budget orion and a soundstream, the soundstream does about 2500w rms dynamichttps://www.amazon.com/Soundstream-AR1-8000D-Arachnid-Monoblock-Amplifier/dp/B01NBYJ901
ehall8702 Posted February 10, 2019 Author Report Posted February 10, 2019 I was looking at the soundstream amps already, didn't figure they were better than the ppi but times have changed i guess. The ppi is putting out good numbers tho ill keep looking. May have to keep reading and researching the AB amps since the subs are awesome. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
ehall8702 Posted February 10, 2019 Author Report Posted February 10, 2019 How about the AB VFL4480.1d thats in my price range also, just the few dynos i have seen AB amps arent putting out the power they are rated for which i guess isnt a bad thing since i will be over powering my subs anyways, just dont like when theybsay i get somwthing and turns out i dont ya know? 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
ehall8702 Posted February 11, 2019 Author Report Posted February 11, 2019 So I decided on the soundstream, and added a matching 4 channel and still within my 250 budget. Matching amps look nice anyways. Going to put my jbl in my girls yukon, she needs a real amp, got a quantum 800 mono on 2 mtx terminator 15s and headunit power on doors. The jbl got more power running in 3 way than the quantum does all day. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
bmwking Posted February 11, 2019 Report Posted February 11, 2019 23 hours ago, ehall8702 said: How about the AB VFL4480.1d thats in my price range also, just the few dynos i have seen AB amps arent putting out the power they are rated for which i guess isnt a bad thing since i will be over powering my subs anyways, just dont like when theybsay i get somwthing and turns out i dont ya know? the 4480 has been the black sheep of AB's line, doesn't do anything close to rated from what i've read. which is a shame. honestly other than the upper VFL line stuff, i probably wouldnt roll the dice on another AB amp. totally would on a wolfram 2400 tho: https://theamplab.net/wolfram-c-2400-1/
bmwking Posted February 11, 2019 Report Posted February 11, 2019 17 hours ago, ehall8702 said: So I decided on the soundstream, and added a matching 4 channel and still within my 250 budget. Matching amps look nice anyways. Going to put my jbl in my girls yukon, she needs a real amp, got a quantum 800 mono on 2 mtx terminator 15s and headunit power on doors. The jbl got more power running in 3 way than the quantum does all day. and just saw this, congrats bud. should sound great (i hope lol)
bmwking Posted February 11, 2019 Report Posted February 11, 2019 and dang, that PPI dyno was a surprise!
ehall8702 Posted February 11, 2019 Author Report Posted February 11, 2019 Still didnt buy those soundstreams so options r still open gonna still take considerations lol will check out the wolfram too, found an AB hd 3500 in my price range. Them any good? I just cant believe they make such great subs and then make bs amps. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
bmwking Posted February 11, 2019 Report Posted February 11, 2019 4 minutes ago, ehall8702 said: Still didnt buy those soundstreams so options r still open gonna still take considerations lol will check out the wolfram too @ $200 that's a killer price
