All Out 170db SPL Build Log (SS 3-4) #AstroAndBass
HOLY CRAP.  This is going to be a sick ass build.
adding the concrete what are you doing about suspension???  ant the EXT is the longer of the astro vans correct.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Likely do a solid suspension, we swapped it over to a beefy set of leaf springs and the weight will be ahead of the rear axel so we will see what it does first. I'm not an expert on the vans but I do believe this is the larger style.
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
Baffle time!
It will consist of a metal frame and start out thin and be added to as it gets tested. I had all the parts made up regardless if I end up using all of them or not.
6CC373B8-D9F5-428D-974A-78E8AFE3AD2F_zps
49A3E87D-C2BD-4898-B7CB-D622549BC48C_zps
3DFB4D68-9FD0-472B-B61B-0356CD40B90A_zps
B44BD67B-98B2-4403-B68E-67592BA09401_zps
CA80C5CD-C0D3-4BC4-B023-6CA3CC664F7A_zps
This layout gave us the most port area possible while still allowing the woofers to fit without issue. It is VERY strong!
Now to cut some wood!! I got the hook up from King's Custom Cabinetry in Sacramento, Ca  and help from Bobby Gately of Gatley Audio to get these parts cut on a CNC.
4319E1A4-51EB-4213-A6B0-440A70A7AA0F_zps
We are using a very high grade MDF, much more dense than whats available at a Homedepot. It also if full dimension thickness which was important for filling in the metal frame as you will see.
FECE76D0-640F-44DF-9B60-08998B140536_zps
4E07BB49-4479-46FC-818D-44344D741531_zps
AA7162C8-1C2D-4EC3-B53C-1DD64AD3E660_zps
DCC94329-4444-44F7-B76F-18D83CD23EAD_zps
Mocking up the baffle. 796287FF-4C38-4E1D-AA57-C45E9261775C_zps
9595F0D6-B4F6-4251-B280-19A0FDAC3205_zps
B0095864-7A18-444F-B1A5-FC4F27AC57A2_zps
5525F71C-49D4-4544-B37E-4D3A09A19E19_zps
88FF525B-BF19-4219-AFDE-1E5DBEBCC875_zps
573ACE73-24D4-4F9F-9471-B44D76A03DEB_zps
12 minutes ago, DiBo said:
No worries of choking the subs down a little bit with that thick of front baffles. Will they be able to breath properly? Just curious.
Looks good BTW.
I don't plan to use all the layers without testing each as its added, also have plans to rear mount the woofers if i start having pressuring issues on the rear cone. Its setup to give me options on 1/4 wave tuning.
That's wassup. Thanks for the clarification. I can't wait to see the results. Big ups to jeep and bass!!
More progress on the baffle and cage being made. We also got our SMD fuse holders made up by the man himself last week!
0FF9273D-96DE-48E7-89F2-AB7543AC12D4_zps
33060533-4A0B-4CE2-908F-C5D9FBB0395D_zps
964D10AD-BFD0-46B2-9D8C-22E6A5A805D7_zps
Traced out the frame onto the first baffle layer to start the pre-drilling process. Then went on to attaching the baffle on using Pl3x and a ton of metal screws.
0DD250A9-F125-46FC-AEFB-18DE4F76D46D_zps
1B3014F5-CC53-40FA-9A59-FB3865387924_zps
6424519C-AF5F-470D-93D6-80BAF4087C4D_zps
This will be the starting thickness of the baffle. It will likely change as we test.
7D9C913A-35DB-4B78-8CC0-1AD33BEE5EB0_zps
1363F638-AB30-4C41-ADE4-CA0227E0E134_zps
D543DD23-C594-49B3-B2DA-6543A8A23302_zps
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
