1 hour ago, CrackFactory said:
Did you leave the stock sub hooked up or did you cut the wires? Some factory amps wont output audio unless it sees a load from a speaker.
He used rear speakers as his tapping point
On 2/18/2019 at 8:48 AM, KCK Jukebox said:
Its best to go at the sub. After amp. I found this diagram in a charger forum for the beats system. Hopefully it matches
Sub 1 +: Gray / Brown
Sub 1 - : Dark Green / Brown
Sub 2 +: Gray / White
Sub 2 - : Dark Green / White
I hooked into these wires from this diagram and things got MUCH cleaner and louder. Actually ran across the same post in a forum yesterday and got it all sorted out for the most part. Still having some issues tuning everything with the LC2i and the Alpine amp but it sounds wayyyy better than before. Thanks guys for all your input!
