BassMunky Posted March 13, 2019 Report Posted March 13, 2019 What has everyone ran in a Chevy equinox? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Joshdashef Posted March 13, 2019 Report Posted March 13, 2019 What power you going to run? Care about leaving any cargo space or using it all for the box? SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
BassMunky Posted March 13, 2019 Author Report Posted March 13, 2019 All about box no space. Go big as can. No wall yet. Power prob around 6k. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Joshdashef Posted March 13, 2019 Report Posted March 13, 2019 Single or dual subs? I bet you can get atleast 4 to 5 cubes with that space no wall SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
BassMunky Posted March 13, 2019 Author Report Posted March 13, 2019 2 subs. 2 15 or if can 2 18. I wanna be able to put back seats up maybe option. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Joshdashef Posted March 13, 2019 Report Posted March 13, 2019 Sundown Zv5s might work for you their rec port vol is 4.5 cubes though so you’d have to dig to get 8 cubes back there atleast. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Joshdashef Posted March 13, 2019 Report Posted March 13, 2019 Cheaper would be psi platform 3s SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
BassMunky Posted March 14, 2019 Author Report Posted March 14, 2019 51 minutes ago, Joshdashef said: Sundown Zv5s might work for you their rec port vol is 4.5 cubes though so you’d have to dig to get 8 cubes back there atleast. 2 15? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 14, 2019 Author Report Posted March 14, 2019 2 15? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Joshdashef Posted March 14, 2019 Report Posted March 14, 2019 yeah two of them SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
