Noah66 Posted March 23, 2019 Report Posted March 23, 2019 Subs popping when I turn key on and still does it when I shut car off no music comes out just popping noise so had to disconnect in-line fuse to stop it any suggestions?
realflow100 Posted March 23, 2019 Report Posted March 23, 2019 ground loop? try unplugging the inputs to the amp high level and low level? is there a bad ground somewhere or a ground loop to the inputs that could be a problem you might need a ground loop isolator Also check that the inputs arent "partially" plugged or unplugged that can cause buzzing and popping and bad outputs too..
Ron36 Posted March 23, 2019 Report Posted March 23, 2019 I’ve seen RCA’s do that stuff before , maybe wiggle or turn them when the systems on to see if it intensifies. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Noah66 Posted March 23, 2019 Author Report Posted March 23, 2019 I have the amp grounded on a kinetic battery
Noah66 Posted March 23, 2019 Author Report Posted March 23, 2019 I think It might be my rca the crome piece is broke off in amp I got it out and amp is in protect mode
realflow100 Posted March 23, 2019 Report Posted March 23, 2019 thats not good. if your amp is broken you might need a new one. if its just the cables then you need new cables. if its both are broken you need new RCA cables and a new amp. thats not good
Noah66 Posted March 24, 2019 Author Report Posted March 24, 2019 Got a new amp and rca and it fixed the problem thanks everyone!!!
