Transmission Line Enclosure help
Kinyo85
How much power are you going to be running?  Reducing the line area can often be beneficial.
Builds:
1 hour ago, Kinyo85 said:
I made the line area a bit smaller is this better or shuld i go with my first plan I will have to run a spacer for the sub to fit
Screenshot_2019-03-25 Dual Fold On-Axis Transmission Line Enclosure Calculator - DB DYNAMIX AUDIO(2).png
That should work well with the power you have on tap.  A couple things to keep in mind, your output is going to roll off once you get much below 40 Hz.  Also be sure to set your subsonic filter to around 30 Hz if you have one, otherwise you run the risk of damaging your sub.
Builds:
To get the enclosure to play lower you need to tune it lower/make the line longer.  If it were me I'd shoot for about a 32 Hz tuning.
Builds:
4 hours ago, Kinyo85 said:
I would love to make the line longer but my max width is 31 inches is there a better sub suited to a t line  or should I build a ported box instead
If you don’t have the space to make the line longer I’d just build a ported box.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 1658 Guests (See full list)
