RF 2500.1bdcp with 2 RF t0 15s -HELP-
I currently have 2 Rockford Fosgate t0 15s. Im thinking on buying RF 2500.1bdcp and just turning the gain down.
the t0 15s can only handle 800rms per sub.
In about a year ill be getting subs that can handle more power.
Ive seen birth sheets of the amp doing around 3k  @1ohm
should i just wire the subs to 4 ohm and the amp will push around 2k and play it safe with the subs, or do 1 ohm and turn the gain close to all the way down? what would you recommend?
That's an expensive amp, I have one and it is definitely worth the price but I would consider the t1500-1bdcp for that setup. If you are set on the t2500-1bdcp then you could run it either way.
