  • Sets audio system gain overlap, continuously variable from 0.0dB - 15.0dB in 0.1dB steps
  • Checks gain overlap of an audio system without making any adjustments to the existing settings
  • Verifies that the gain overlap of an install hasn't been tampered with after install
  • Features our Patent Pending Distortion Detection system plus digital microcontroller and our proprietary firmware
  • 200V maximum input (same as DD-1 HV)
  • Quasi-RMS voltmeter (can detect clipping at any frequency)
The plus allows a more precise overlap setting than the regular DD-1. The regular, you're limited to what comes on the disc, or any other specific overlap tones you may get from another source (such as a thread on this forum). The plus shows you exactly what overlap you are setting to in .1 increments.
Steve Meade has videos documenting what each of his products does and how to use them properly. Look up his YouTube channel or look around this forum for them.
 It should be fine on the home amp as long as there is a way to connect to the DD-1.
