I would like to know if the dd1 would work ok to set gains on a pa amp? also will it work to find the clipping point of a preamp and an active rca to xlr di box converter?
thanks
riden high on 37s
square body cause I dont like plastic 4X4s
It should work with any signal, but I’m no expert on the device.
  • Thanks (+1 Rep) 1
♦ Sundown NSV4 18"  +  Sundown SALT-4 Baby
♦ MechMan Elite 370a  +  XS3100 - XP3000
♦ SHCA 1/0 OFC(blue)  +  SMD Fuse Holders(blue)
♦ Pioneer AVH-2440NEX  +  SHCA Pro RCA
thanks I would think it would work fine with home/pro stuff but wanted to check. I hope some one with more info will chime in.
riden high on 37s
  • 1 month later...
I would have to assume so, distortion in an audio signal is distortion......at least I think? FYI, best money one can spend, if you want your amps tuned correctly. It worked wonders for my nephew and I's systems.
  • Thanks (+1 Rep) 1
2007 Monte Carlo SS,
Kenwood DDN 9702S
(2) JL Audio C2 650 6.5's with tweet
(2) JL Audio C2 690TX 6x9's
(2) 10" JL Audio W6's
(1) Arc Audio XDi 600.4
(1) Zapco ST-2000XM II
Knukonceptz 1/0 gauge, 4 gauge, 8, gauge, 12 gauge
250A Singer Alt.
SMD DD-1
thanks for the replies will have to get a dd1 at some point.
riden high on 37s
Just make sure if you change any setting in ur deck and I mean any setting to recheck rca out distortion.
I had all mine set and unhooked the battery’s to work on wiring upgrades and for some reason it reset all my setting in my deck which has never happened  before.
I ended up blowing a coil because time alignment got turned in by default and caused me to clip at volume 32 and I had it set to 40 going full blast.  So 8 past clipping lol.
250 dollar mistake I will never do again, I almost cried when it happened.  Now at any high volume it makes a loud ping sound, and if you push down on the dust cap you can hear it rubbing on something.
Glade a drop in kit for an NSV4 is only 250 when the sub cost 1150 dollars.
Edited by Dragonsyph
  • Who's Online   0 Members, 0 Anonymous, 3366 Guests (See full list)
