Active front stage
jnasty
Hey guys, so I've paid so much attention to my bottom end.. I've kinda settled for sub par mids/highs. I've got 2 JBL gti660's in each front door with the matching tweet in the sail. Now, I've got the option to give each mid it's own channel through the dsp & amp. Should I treat the two 6.5's in each door as a single speaker and bridge the amp orrr use all 4 channels thus giving each mid it's own option for time delay/tuning? They aren't separated from on another in the back of the door ...
Vehicle: 2002 Ford Escape
Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps
Head Unit: Apple iPad Hi-Res Passthrough Topping d10s
Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0
Sub Stage: (2) TC Sounds LMS Ultra 5400 18"
Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE
Processing: Helix DSP Pro W/ Dash Mounted Director
I thought you could fit a single 8 in each door ...
Personally, I’d run each driver on it’s own channel and leave the control to the Helix.
Do you only have the aformentioned speakers in the front doors or are there other rear door speakers as well? I take it you're running the rockford T1000.4 on the front mids and tweets?
If you gave each mid it's own channel you would still need another amp for the highs if you wanted it active. Im sure you know this.
Yeah, each door houses two 6.5's with a tweet in the sail. I've got the t1000-4 on just the mids & a t400-2 on the tweets
As of now Ive got the 1000-4 bridged to 2ch and treating the two mids in each door as one channel.. wasn't sure if I should go ahead and separate them and get a little more tuning capability with each mid on its own channel
Ohhh & no rear speakers at all, just front stage
I read your post wrong.
I’d run a much stronger 2 channel before i’d Bridge a 4 channel any day. Just never been a fan of bridging 4 channel amplifiers.
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
