Mike4068 Posted June 29, 2019 Report Posted June 29, 2019 Anyone have any ideas on what might be causing the intermittent whine I'm getting from my system? I've ruled out alternator whine as rpms have no effect on the whine. It comes and goes but it does so in an almost cyclical manner. Maybe toroidal transformer or hu? Amp is rf t1000-4ad running 4 sets of coax speakers. Ground is solid reading 0 ohms. Thanks gentlemen.
Guest Posted June 29, 2019 Report Posted June 29, 2019 your rca is too cheap or u have it ran on the wrong side of the car
Mike4068 Posted June 29, 2019 Author Report Posted June 29, 2019 3 hours ago, Gunnem said: your rca is too cheap or u have it ran on the wrong side of the ca They are kicker K series rca's. They are ran on the passenger side and my power is ran on the driver's side. 3 hours ago, Gunnem said:
Djboss Posted June 29, 2019 Report Posted June 29, 2019 I would try a ground loop isolator see if that removes the noise, and if that doesn't work you could have a defective amp. https://www.sonicelectronix.com/item_5262_PAC-SNI-1.html?msclkid=ec72b024a69a14c47792ed3397e297a1&utm_source=bing&utm_medium=cpc&utm_campaign=DSA - Dynamic Search Ads&utm_term=car speaker&utm_content=DSA - Car Speakers
reedal Posted June 29, 2019 Report Posted June 29, 2019 What Head Unit? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Mike4068 Posted June 29, 2019 Author Report Posted June 29, 2019 2 hours ago, Djboss said: I would try a ground loop isolator see if that removes the noise, and if that doesn't work you could have a defective amp. https://www.sonicelectronix.com/item_5262_PAC-SNI-1.html?msclkid=ec72b024a69a14c47792ed3397e297a1&utm_source=bing&utm_medium=cpc&utm_campaign=DSA - Dynamic Search Ads&utm_term=car speaker&utm_content=DSA - Car Speakers Yeah, I'm afraid that it's the amp. It's not a ground loop problem but thanks for the link!
Mike4068 Posted June 29, 2019 Author Report Posted June 29, 2019 49 minutes ago, reedal said: What Head Unit? JVC KD-R975BTS
SkarredSierra Posted June 29, 2019 Report Posted June 29, 2019 Do u have an extra amp or headunit? I keep an older headunit and a few old amps around ik work to troubleshoot issues like this. Doesnt need to b anything fancy or expensive. flea market amps will work. Id say its probly one of those 2 unless ur rca became compromised somehow such as a pinch or factory defect or age.
Mike4068 Posted June 29, 2019 Author Report Posted June 29, 2019 2 hours ago, Gunnem said: that could be your problem, a $60 radio Worked fine with the other amps before upgrading but I've had it since it first came out so it could be going to shit but I bet it is the amp.
